Building muffs for comparison
zeropluszero
I've ordered a Double Muff with my last PCB order, and was thinking of breadboarding the muffin fuzz variants before committing.
I was hoping to get another set of eyes over a few parts lists to add to the existing options, I've made some educated guesses with some of them but am open to correction.
Shika
R1 33k
R2 82k
R3 390k
R4 18k
R5 100r
R6 820r
R7 8.2k
R8 82k
R9 390k
R10 12k
R11 150r
R12 8.2k
R13 82k
R14 390k
R15 18k
R16 100r
R17 39k***
R18 39k***
R19 47k
R20 390k
R21 12k
R22 1k
R23 1M
R24 (Bypass)
C1 100nf
C2 560pf
C3 100nf
C4 100nf
C5 47nf
C6 560pf
C7 100nf
C8 47nf
C9 560pf
C10 3.3nf***
C11 10nf***
C12 100nf
C13 100nf
C14 220uf
C15 jumper***
Q1 2N3904
Q2 2N3904
Q3 2N3904
Q4 2N3904
D1 1N4148
D2 1N4148
D3 1N4148
D4 1N4148
SUSTAIN B50K (On a double muff, I guess I can solder some 50K resistors over pins 1 & 3?)
TONE B50K
VOLUME B50K
Kewpie
R1 33K
R2 100k
R3 470k
R4 10k
R5 150R
R6 1K
R7 10k
R8 100k
R9 470k
R10 10k
R11 150R
R12 10k
R13 100k
R14 470k
R15 10k
R16 150R
R17 33k
R18 24K
R19 100k
R20 1k
R21 10K
R22 2.7K
R23 1M
R24 (bypass)
C1 100nf
C2 560pf
C3 100nf
C4 100nf
C5 47nf
C6 470pf
C7 100nf
C8 47nf
C9 470pf
C10 4.7nf
C11 10nf ??
C12 100nf
C13 100nf
C14 47uf
C15 (Jumper)
Q1 2N5088
Q2 2N5088
Q3 2N5088
Q4 2N5088
D1 1N914
D2 1N914
D3 1N914
D4 1N914
SUSTAIN B100K
TONE B100K
VOLUME B100K
Ungula
R1 39k
R2 100k
R3 470k
R4 15k
R5 100R
R6 2.2K
R7 8.2K
R8 100K
R9 470K
R10 15K
R11 100R
R12 8.2K
R13 100K
R14 470K
R15 15K
R16 100R
R17 39K
R18 2.2K
R19 100K
R20 390K
R21 10K
R22 2.2K
R23 1M
R24 (jumper)
C1 100nf
C2 470pf
C3 100nf
C4 100nf
C5 100nf
C6 470pf
C7 100nf
C8 100nf
C9 470pf
C10 6.8nf
C11 6.8nf
C12 100nf
C13 100nf
C14 100uf
C15 (omit)
Q1 2N3904
Q2 NPN germanium low leakage
Q3 NPN germanium low leakage
Q4 2N3904
D1 Red LED
D2 Red LED
D3 Red LED
D4 Red LED
SUSTAIN B50K
TONE B100K
VOLUME B100K
Before soldering the 50k resistors over pot-legs 1&3, use some alligator clips to audition the resistors and see if you even want/need them.
On one hand, it makes most sense to choose two very different circuits for the Double Muff, but the PCB could also be used for two subtle variants.
I've been toying with the idea of breaking out the Dual-Gangs to single gangs and making the channel switch a stomper. Then I can have two Identical/near-identical Muffs but set up very differently from each other, say for example one set to low-gain and bright tone while the other is bombastic bassy fuzz. Of course, it'd be fun to have two vastly different circuits, and still do the break-out pots and stomper-channel-switching idea, too.
So many options... such a great PCB idea.
