Butt Head Tayda Template
greypilgrim76
Hi All,
Quick question: I've built out the PCB for the Butt Head Distortion, and I'm getting ready to order the enclosure for it and some other pedals, but there's not Tayda drilling template for the Butt Head on the product page. Does anyone know if this one would work for the Butt Head?
Many thanks for any guidance!
PS--Bonus points if anyone can confirm that this one will work for the Muffinator:
Butt Head Distortion looks to be the standard PPCB 4 knob layout, so you can take the drill template from https://www.pedalpcb.com/product/pcb251/ for example.
The trick I do to check those sometimes is that I open both build docs (one with a verified Tayda drill link and one without) in different browser tabs, scroll to the drill template, and then just quickly switch between them using Ctrl+Tab and Ctrl+Shift+Tab. Those two are clearly identical, although with some experience you could tell it's the 4 knob layout.
I think this one is for Muffinator, you can compare it to yours https://forum.pedalpcb.com/threads/anyone-build-a-template-for-muffinator-fuzz.26050/, seems to be verified now.
