nate433
I have a friend who wants a Big Muff with a clean blend. This hitch is he wants the clean blend on a footswitch so that he can toggle it off mid song and get the full blown fuzz.
Would it be as simple as a adding a switch in the blend path like this to disconnect it (Obsidious for example):
Or would there be more to consider?
Would the best way be to add a buffer at the beginner and end like this the above schematic? I've only used the Buff N Blend daughterboards in the past when adding a blend, so this is all new to me but it feels possible.
____________________________________________________________________________________________________________________________________________________________
Alternatively he has a weirder idea:
1. There's a toggle that either combines the clean and fuzz signal into one output or splits them so that fuzz is in one and clean is in the other.
2. A footswitch that can turn off the clean, but when it does the fuzz is sent out to both outputs
Now this one I have no idea if that is even remotely possible but here are some drawings he gave
Thanks!
Thanks!
