Rpschultz13
Just built a Caesar (Walrus Julia) chorus. Normally this has 2 LED's: on/off and pulse rate. The Pulse LED is the D_LFO in the below schematic. I was hoping to combine these into 1 LED that only pulses when it's ON - and is off (and doesn't pulse) when it's off. I tried, but I couldn't figure it out. Seems simple enough to just connect those circuits together somehow, but they are both tapping off ~9v (give or take). So I think it needs to be on the D_LFO circuit, basically ignoring the LED-R103 circuit. Somehow adding the 3DPT switch into the D_LFO leg. ?
Any help would be appreciated.
As it is now, I use an illuminated LED switch and breakout board from PPCB, basically jumpering the A-K holes on the circuit board. Both LEDR's are sticking up in the picture, messing with values. The A-K on the left is the switch using a 4k7 LEDR, and the A-K on the right is the Pulse using 6k8 LEDR.
I should add I got both LEDs working individually (one pulsed), just couldn’t figure out how to combine them.
