I've built a Captain Bit and it sounds as it should, it sounds very good in fact. But there is quite a bit of background static and white noise, it's present even when the guitar's volume is turned down. I can cut it back quite a bit if I turn the "up" and "filter" counter clockwise to cut out the high frequencies but its still there. Also the level of this pedal is WAY loud, unity gain is like... 9 o'clock on the level pot? I've been fooled before with unconventional pedals though, not realizing that they sound or operate strangely and that's how they're supposed to work. Can anyone weigh in if that might be the case here?
I did try to reflow anything that looked off, and also pressed around to see if there were any components not making proper contact.
