Cephid Chorus is a little thin
designatedmedia
Hey all, just built a Cephid with NOS pana chips, tested all parts prior to installing, values were all consistent with build sheet. A/B’d it with a 18V Cool Cat chorus and the cool cat lets more bottom end pass through for whatever reason. If I’d like to increase the bottom end response of the Cephid what cap should I increase? Thanks!
Reactions: fig
I think you'd get more hits in the Modification section. ;)
There are several staging filters in this circuit. There is a smaller window of bandwidth to avoid aliasing on the lower end frequencies and clock noise in the higher range (something like 50Hz-5kHz I think).
