ch341eeprom command not found
sudo ./ch341eeprom -s 24c32 -w bypass.bin
Thanks daeg, I was omitting ./ which was the reason I was getting the 'no such file' error.
I was wondering why in some instances it's not needed, as the example on the wiki page.
I've had this error only the first time I've successfully run the program.
libusb: info [darwin_detatch_kernel_driver] no capture entitlements. may not be able to detach the kernel driver for this device
libusb: info [darwin_claim_interface] no interface found; setting configuration: 1
So happy to not have to switch to windows just to flash a bank!
If you type the command 'echo $PATH' you should see a list of directories. If you copy ch341eeprom to one of these directories you will no longer need to type the "./" any more.
I am a linux user so I'm not sure what the correct directory on a mac would be, but on linux I copied ch341eeprom to "~/.local/bin".
Reactions: fig
I'm sorry I'm resurrecting a 2 year old thread but I though I'd try some previous posts before posting a new one.
I am determined to flash a blank but I have no idea how code works or what to do to get it to work on my mac.
Sorry for posting in an old thread, but it looks like people have walked down the path I am currently on. I have everything installed correctly I believe, but when I run "sudo ch341eeprom -s 24c32 -r currentbank.bin", I an getting "Segmentation fault: 11"
I am using a CH341 EEPROM Programmer as I am still waiting for the WCH chips to arrive for my PedalPCB FV1 Dev board.
Any thoughts on what could be the issue?
What's your OS?
