Champagneperfume
Hey gang,
I recently completed my second chaos machine build. I'm absolutely thrilled with the first build. Gorgeous sounds and so many tonal options.
The second build is powering on and sort of working. I've tested them side by side for a shoot out test while matching the same knob settings on each and I've noticed the newest/second build just isn't as saturated effect wise. I'd say it's about 70 percent there, compared to the first build. Can anyone point me in the right direction as to why this is happening? I've swapped out the TL072's and the JRC4588D and I still get the same result. I've also reflowed solder points that looked slightly suspicious. Thanks in advance.
