untamedfrontier
Here's the petal chorus example ported over.
There are definitely some issues with it. Things that are obviously wrong are related to the encoder. I didn't have any success applying advice from the knobs as encoder thread, because I've been unable to debug the pot_rotary not being declared in this scope error, so you'll see this code just has me seeing if I could figure out how to set dry/wet using a knob (I could not).
I commented out the LED stuff related to the encoder in the main, but I probably also did something wrong there. However, that being said, this will build and actually sounds pretty decent having not tweaked anything yet. I can share a bin if anyone has issues.
Code:
// porting chorus example - v1.0
#include "daisy_petal.h"
#include "daisysp.h"
#include "terrarium.h"
using namespace daisy;
using namespace daisysp;
using namespace terrarium;
DaisyPetal hw;
Chorus ch; //defaults to 2 delay lines
bool effectOn;
float wet;
Led led1, led2;
float deltarget, del;
float lfotarget, lfo;
void Controls()
hw.ProcessAllControls();
//knobs
float k = hw.knob[Terrarium::KNOB_1].Process();
ch.SetLfoFreq(k * k * 20.f);
lfo = hw.knob[Terrarium::KNOB_2].Process();
del = hw.knob[Terrarium::KNOB_3].Process();
ch.SetFeedback(hw.knob[Terrarium::KNOB_4].Process());
//footswitch
// effectOn ^= hw.switches[0].RisingEdge();
if (hw.switches[Terrarium::FOOTSWITCH_1].RisingEdge())
effectOn = !effectOn;
led1.Set(effectOn ? 0.0f : 1.0f);
//encoder
// wet += hw.encoder.Increment() * .05f;
wet += hw.knob[Terrarium::KNOB_6].Process();
wet = fclamp(wet, 0.f, 1.f);
wet = hw.encoder.RisingEdge() ? .9f : wet;
void InitLeds(void)
led1.Init(hw.seed.GetPin(Terrarium::LED_1),true);
led2.Init(hw.seed.GetPin(Terrarium::LED_2),false);
void AudioCallback(float **in, float **out, size_t size)
Controls();
led1.Update();
led2.Update();
for(size_t i = 0; i < size; i++)
fonepole(del, deltarget, .0001f); //smooth at audio rate
ch.SetDelay(del);
fonepole(lfo, lfotarget, .0001f); //smooth at audio rate
ch.SetLfoDepth(lfo);
out[0][i] = in[0][i];
out[1][i] = in[1][i];
if(effectOn)
ch.Process(in[0][i]);
out[0][i] = ch.GetLeft() * wet + in[0][i] * (1.f - wet);
out[1][i] = ch.GetRight() * wet + in[1][i] * (1.f - wet);
int main(void)
hw.Init();
float sample_rate = hw.AudioSampleRate();
InitLeds();
ch.Init(sample_rate);
effectOn = true;
wet = .9f;
deltarget = del = 0.f;
lfotarget = lfo = 0.f;
hw.StartAdc();
hw.StartAudio(AudioCallback);
while(1)
hw.DelayMs(6);
/* hw.ClearLeds();
hw.SetFootswitchLed((DaisyPetal::FootswitchLed)0, (float)effectOn);
int wet_int = (int)(wet * 8.f);
float wet_frac = wet - wet_int;
for(int i = 0; i < wet_int; i++)
hw.SetRingLed((DaisyPetal::RingLed)i, 1.f, 0.f, 0.f);
if(wet_int < 8)
hw.SetRingLed((DaisyPetal::RingLed)wet_int, wet_frac, 0.f, 0.f);
hw.UpdateLeds();
