Hi, first time here. Loving all the designs by PedalPCB and really looking forward into building quite a bunch. But I have found an issue when starting a Circulator. My PCB has the values of each component instead of R1, R2, etc printed (so for example, in the place of R1 it directly says 10k). Problem is checking the BOM R4 is supposed to be a 10k resistor, but on my PCB the print says 100K, so R26 and R4 seem to be the other way around. Is this something known (I havent found anything doing a quick search)?
I am following the official pdf (https://docs.pedalpcb.com/project/Circulator.pdf) but my PCB only has the actual component values printed.
Thanks!
Thanks!
