REQUEST Cleric Fuzz Drill Template - Tayda
tremolowe
Hello! I'd like to get a pre-drilled enclosure from Tayda and I just want to make sure that the extra hole is in the right place! Has anyone ordered one from them before so I can get it right? Thank you in advance for your time!
I'm sorry to say I don't have a drill template for you that has the switch located, but a tip for situations like these where there's a switch in a non standard spot; I'll usually still have tayda drill out everything else for me with my standard 3 knob template and then use the build docs template to do the switch myself. It's not 100% ideal, but it does work 🤷‍♀️
here's the standard 3 knob template I use with a center led sized for a fresnel lens in case you need it - https://drill.taydakits.com/box-designs/new?public_key=cFJXNEg3UDZPS1c5Y25mQkRFaXpUdz09Cg==
