Hi all. I recently finished a Notakliche build and as part of the final process, I auditioned a bunch of diodes using tacked in croc clips to permit fairly quick changes. I found a few elements of this to be slightly odd.
I began by placing germanium diodes per the schematic and trying various diodes in the position controlled by the switch. After a short while of confusion and looking at the schematic, it became obvious why I was hearing no difference between diodes given the germanium diodes have a lower forward voltage and essentially prevent other types of diodes from doing any of the work. WDJD makes sense now!
I then tried some Schottky diodes given their lower forward voltage but again, I didn't hear anything different when bringing them in with the switch. I decided to change the germanium diode location such that they would be brought in by the switch, allowing me to audition different diodes to go in their place.
I tried LEDs, normal silicon diodes, etc. and the differences were fairly subtle. That's when I decided to listen with no diodes at all and there really wasn't much of a reduction in distortion. Things were a bit wilder, but the character remained very similar. For now I have therefore landed on no diodes in the normal position and germanium diodes in the switch position.
Given all the talk about magic diodes, and them being in a hard clipping arrangement, I really wasn't expecting it to sound dirty without any diodes. Is this normal? I presume this is the sound of overloaded opamps?
With that in mind, I did one last check before quitting which was a bit of a voltage survey across the board. To my surprise, the voltages all seem to sag a fair bit. Maybe this is normal given the 9v supply runs through a 100 ohm resistor? Here's what I measured:
+9v rail is +7.5v
+18v rail is 13.3v
-9v rail is - 6.7v
Vref (ideally 4.5v) is 3.7v
Removing the opamps results in the voltages rising up much closer to the stated values on the schematic, less the diode drop. On this basis I think the 100 ohm resistor might be the culprit which makes me question its purpose.
Please note I got the optivisors out and checked the entire board for soldering issues, all seems to be in order. I also removed and reseated the opamps and charge pump IC. I also built it using parts from Mouser so fake ICs isn't a concern.
Sorry for the long read but if you have any thoughts on whether my pedal is behaving oddly or if this is totally normal, I'd love to hear it.
Sorry also if this should be under troubleshooting. I suspect my pedal is behaving normally and I'm just not quite understanding how it works, hence why I posted this in General.
+9v rail is +7.5v
+18v rail is 13.3v
-9v rail is - 6.7v
