Comparison of Tuners and Q-tune
Rpschultz13
Here is a comparison video of Q-tune and the 3 top tuners IMO, from Right to Left:
Polytune 3 in Buffer Monitor Mode
Q-tune (1590b) in Buffer Monitor Mode
Peterson Mini in Buffer Monitor Mode
Turbo Tuner 300 Mini in True Bypass (Buffer not available)
Similar to the above, only with Q-tune "Techie" Tuning Style.
Notice that the accuracy against a tone generator is generally +/- 0.05 Hz. With most of the strings this is <0.1 Cents, but as the frequency gets lower the distance between semitones decreases. And so even though the frequency accuracy remains about the same, the Cent accuracy decreases.
And here is what the waveform looks like for a guitar string. See how complicated it is. This is the challenge of writing tuning algorithms. The frequency of a simple sinewave is easy with a common zero-crossing algorithm. But a vibrating string is much more complicated, you can see the harmonics in the below video.
The Q-DSP-library that we are using (yes that's why we named it Q-tune) is very sophisticated. A very simple explanation is that it takes the signal, converts the zero crossings data to bitstream (1s and 0s) and THEN uses an autocorrelation algorithm of that.
I guess I didn't realize this until recently but it looks like Q-tune and Peterson have a very similar spin rate, while Poly3 is about twice as fast and TurboTuner is WAY faster. I've used TT for so long it never bothered me. But now I think I like the slower rate.
Here's another comparison with Canvas included. Something odd happens with Canvas on some notes, it's a small error but considering that the other 4 tuners are rock solid together on a waveform generator, it is strange.
