Could I Add a Relay to an Existing Pedal’s Toggle?
I’d like to install a Pinstripe DISO+ (with the polarity rev switch) on my pedalboard but I need to control the polarity switch externally through one of the function switches on my PBC6X.
I confirmed with Pinstripe that the installed polarity toggle is a DPDT switch. In theory, could I use this relay circuit to accomplish this?
(Not sure if I need the latching or non-latching)
Not sure if there’s space inside, but ideally it would be great to build it into this enclosure, still leave the existing toggle in place, and simply install a 1/4” jack to connect a cable to the PBC6X. But I’m not opposed to building a small external box if need be.
E5BC77E9-A1E5-4D41-8F94-BF17327FE9FF.jpeg 46B32DFA-D0AF-49B1-9263-5F4FF0D7C7C1.jpeg 1B67A757-56C3-4416-9D23-498C691E725C.jpeg
