XNFrank
Authorized Vendor
First facebook decided I was a bot and messed up the accounts so the old Experimental Noize page there is gone, new ones at https://www.facebook.com/profile.php?id=61594580558568
Second we now have a web based gooeycore editor, assembler and simulator with register display and break point settings at: https://gs.experimentalnoize.com/
Quick instructions:
1. Click "+Lib Folder" and select your local directory of libraries
2. Click "Open" to load a design from your local computer
3. Click "Build & Run" to assemble the design and load it into the simulator, note it will d/l the assembled files and hex to you at the same time.
4. Click "Play" to simulate the program and open the register viewer. You can adjust setting, select waveform or upload an audio file for testing.
Additionally you can program an FXCore based sandbox pedal or dev board attached via USB (must use chromium based browser for this), if on a non-chromium based browser can rename the hex file to output.hex and copy to the sandbox pedal in the file browser.
If you do not have the FXCore tools installed on your PC and just want the library files and gooeycore design files they can be downloaded from our github repository at https://github.com/ftxnoize/FXCore
Quick instructions:1. Click "+Lib Folder" and select your local directory of libraries
