D3lay aka Pythagoras finished!
Build Rating
5.00 star(s)
This was my first surface mount pedal (Spin FV-1). I was a little intimidated at first but it wasn't too bad. I kind of got some liquid flux under the Spin chip which I cant clean but the pedal still works and sounds great so I guess it was ok? Demo soon, hopefully...
I think I'm done painting pedal too... It's too messy and not great to breath in so I bought a metal letter stamp set from Harbor Freight and they totally don't work lol... So I'll have to go another route I guess... not painting ever again lol...
I bent the LED leads to go over the board instead of under which made things easier too. I can just push the LED out from the top of the pedal when I want to take out the inside.
For some reason when I was printing the template for the drill holes they weren't lining up right. I had this issue with the ElectroVibe too. For some reason my printer has a "more settings" options and there has "Actual size" NOT "printable area"... So after putting it on actual size that everything lined up perfectly :)
Can't wait to jam out on this!
Hi Robert! I get my parts from Tayda Electronics for the most part. I use those ceramic caps when it come to Pico values because Tayda for the most part doesnt have those values in a box film cap. If you can find them in a box film then I'd go with those. As far as sound difference between ceramic Pico caps vs box film Pico caps I'm not sure. All I try to do is keep values where they should be so I test all components. The D3lay sounds really good too! Hope that answers your question :)
