DeadEnd FX Trahald (Rumble fuzz 2)
leadfoot
Build Rating
5.00 star(s)
This build came together really quickly. It appears to be lacking the 3rd voicing that exists in the original pedal (which I assume bypasses the voicings) however, that isn't a big deal since only one of the voicings really tickles my fancy.
There were a few time-consuming parts: finding transistors with the needed hfe (I ended up using bc109c and 2n2222a) and then drilling the case as their drill template was/is non-existent. I used Huntington Audio's ZIF breakout and my Peak DCA to speed it up.
With the case, a few minutes with a square and some calipers and I had it complete. As you can see it's a tight fit into a 125b but it does work quite well.
I still need to grab my paint pins and draw Namazu, the God of Earthquakes, onto the pedal.
