iamjackslackof
- Build Rating
- 5.00 star(s)
Howdy fellow builders,
I just finished up a DeadEndFX Hooke true spring reverb, which is clone of the Spaceman Effects Orion. There are some other build reports on the forum that cover it in good detail, so I won't go too much into it. I will say I this is one of the most satisfying builds I've done yet, for a few reasons. One, from purchase to completion was forever in pedal time, several months. This was mainly due to how long it took to source parts, and someawful-no-pedal-building-time vacations. There are a couple of relatively hard to find parts, like the TLP222G and the TDA7052B. Both I managed to get off Ebay, and both were legit and actually worked. And note it MUST be a TDA7052B and not A or C, etc. Luckily the MCU for the Coda-style relay switching was included from DEFX. I did get a bogus BS250 JFET (Jameco I think), but realized after a J201 works fine, and it fired right up after the swap.
Another reason it was so satisfying is that it is a rather complex build, relative to a standard PPCB drive pedal. This was the first stacked build I've done, and the first involving a real reverb tank. I had to make a quick run to the hardware store after I realized the standoff I had were too big for the mounting holes, but it gave me the chance to find some nylon bolts, nuts, and standoffs, which I assume is better than a conductive metal.
Build-wise, I had planned on doing the whole mount the tank to the backplate with springs thing, but I discovered through some highly scientific experimental slapping of the pedal, the tank really didn't crash much unless I was very intentional and forceful. So I just Velcro'd it to the underside of the enclosure top. It will sit on a pedalboard, and I'm not likely to need to intentionally make it crash, so it's much simpler and quicker the Velcro way.
Also I discovered I didn't have the proper headers for connecting the upper and lower boards, so I finally had an opportunity to use my new wire ferrule crimper set, and it turned out great.
As you can see in one of the pics, I have it following my newly acquired T-Rex Replicator Jr tape delay, and the combination of tape into springs is simply heavenly
A final request: does anyone know how to up the intensity of the reverb a bit? I've read of mods to the Dwell section, and I might need to get a longer delay tank. I don't use super long heavy reverb ordinarily, but I'd like to have it on tap.
Thanks for reading!
Thanks for reading!
