THE FORUM LOSING THE FORMATTING FROM A SIMPLE RTF DOC IS A TOTAL PITA!!!
REVERB
Name     Knob 1     Knob 2     Knob 3
️Plate Reverb    (by Spinsemi)
         Pre-delay     Time     Damping
Plate Reverb    (Dattorro Mix Reverb By mdroberts.)
Plate Reverb     (By mdroberts, from Dattorro's paper)
    Reverb level     Reverb time     Damping
Plate Reverb     (Dattorro Mix Reverb. By mdroberts.)
    Pre-delay     Time     Filter
️Hall Reverb     Pre-delay     Reverb time     Damping
️Room Reverb     Pre-delay     Reverb time     Damping
Gated Reverb     Pre-delay     Gate time     Damping
Echo Reverb     Delay     Repeat     Reverb
Chorus Reverb     Chorus-width     Sweep-rate     Reverb
Flange-verb     Reverb     Rate     Feedback
️Tremolo + Reverb     Reverb     Rate     Level
Reverb + HP + LP    (Reverb + 2-pole HP & 2-pole LP)
    Reverb     HPF     LPF
️Reverb + Flange + LP    (Reverb plus flange plus 4-pole low pass. Zero delay with flanger fully counter-clockwise. If you take the time to dial in the LP filter, and adjust the wet/dry mix, you can get some amazing sounds that have a rare blend of being both unusual and very usable.)
    Reverb     Flanger     LPF
Reverb + Pitch + LP    Reverb     Pitch (down)    LPF     4-pole    (May be bit laggy?)
Pitch + Reverb karaoke       ?     ?     ?
Reverb/RT/D/F     Reverb time     Diffusion      High/Low Frequency Damping
Plate Reverb: Very Tight    (extreme density, bit tinny, explosive attack)
    Reverb time     Low freq loss     High freq loss
Plate Reverb: Tight     (very high density, bit tinny, explosive attack)
Plate Reverb: Lush    (very high density, explosive attack, large)
Plate Verb + Shimmer    Shimmer     Reverb time     Damping    (Dattorro Mix Reverb)
Plate Verb+Oct+Shim     Shimmer-level     Time     Damping    (Dattorro Mix Reverb)
Plate Reverb + LPF         Filter     Time     Damping    (Dattorro Mix Reverb)
Plate Reverb + Octave     (Dattorro plate+fixed 1-oct freq shift)
    Shift level     Time     Damping
Plate+Pitch-Shift+Fdbck     (Dattorro Verb+vari-freq shift on input, feedback)
    Freq-shift     Time     Damping
Plate Verb+Pitch Shift     (Dattorro Verb+vari-freq shift on input)
1-Head Tape Echo+Spring    Time     Feedback         Reverb
️2-Head Tape Echo+Spring    Time     Feedback     Reverb
1-Head Echo+Sprg+PingPong     Time     Feedback         Level
2-Head Echo+Sprg+PingPong    Time     Feedback     Level
1-Head Tape Echo+Verb            Time     Feedback     Damping
2-Head Echo+Plate+PingPong     (Verb code is 2 tap version of Spin OEM1 Vocal Plate)
2-Head Echo+Plate Verb    (Verb code is 2 tap version of Spin OEM1 Vocal Plate)
Freeverb    (Stereo based on Jezar's public domain C++ sources, composed of eight parallel comb filters on both channels, followed by four all-pass units in series. The filters on the right channel are slightly detuned compared to the left channel in order to create a stereo effect.)
    Comb feedback         —     —
Reverse Reverb     Pre-delay     Decay time     Damping
Hall Reverb w/ Shimmer     Damping     Feedback     Decay
New Shimmer Reverb     Shimmer     Reverb level     Reverb time
Interesting — w/ Overdrive    (OD to flanger & HP/delay, verb driven direct from input)
Interesting — v1    (Flanger&HP/delay, Verb direct from input+envelope filter)
Room reverb: 3-4-5    (3 delay lines with relative lengths in a ratio of 3 - 4 - 5)
️Spring Reverb + Tremolo    (cut tremolo depth for just good spring reverb)
    Reverb     Rate     Depth
Firesledge Reverb (bass)     (Simple reverberation designed for bass)
    Time     Filter         Mix
️DRolo Reverb     Decay     Pre-delay     Filter
Minimal Reverb     —    —    —
