aienco
Hello everyone. I have just finished building the above. I have been troubleshooting an issue for a couple of days and tried all I know, so I am looking for some guidance please?
Pass through working fine. As soon as I switch it on, LED lights, but sound is dead. With the probe I have found that pin 3 on IC1 has sound but pin 1, which I assume is where it should be coming out from, has just noise. Same with resistor R3. So from there I took Voltage readings on IC1 which are not right. I checked D1 and have 9.1V, D2 is giving me a strage voltage of -3.4V? I would have thought it should be around 9V too? I have reflowed/re-soldered the whole board, replaced IC1 with a new one I had. I know the voltages on the IC are too low, but I don't know where else to look.
I measured voltages around the power coming in, but as I stated, other than the incoming voltage, I am not sure what the others should be? Voltages of IC1 are as follows?
1. 0V
2. 0V
3. 0.5V
4. 0V
5. 0.6
6. 0.8
7. 0.8
8. 1.3V
So I know these voltages are way too low and other than the above attemps, all I keep doing is going over the same things. That's when I admitted defeat and thought I would get some assistance...
Oh IC 2 Voltages
1 8.9
2 4.5
3 0
4 0
5 0
6 4.1
7 5.8
8. 8.9
Would welcome any guidance please?
6
1. 0V
2. 0V
3. 0.5V
4. 0V
5. 0.6
6. 0.8
7. 0.8
8. 1.3V
Oh IC 2 Voltages
1 8.9
2 4.5
3 0
4 0
5 0
6 4.1
7 5.8
8. 8.9
6
