Demonfx The Dual Gun - Mods!
music6000
This Pedal sounds Great & PCB Build is very good!
The area where it fails is the 2 toggle switch's!!!
They used standard length toggle levers with chrome bush & when the Footswitch's are pressed down, they are lower than the toggle levers!!!!!!
I replaced them with Short lever SPDT On/Off/On with nuts!!!
The Volume & Tone knobs are cheap push on D shaft style, I upgraded to LMS Solid Aluminium with Black Grub screws
For $160.00AU including shipping, It was stll a good purchase:
Demonfx The Dual Gun Overdrive Pedal 2.jpg Demonfx The Dual Gun Removed Parts.jpg
I'm impressed with my DemonFX "King of Drive", great sounding pedal. How does Channel 2 sound on this pedal? I just ordered the "King's Hand" pcb that's just Channel B of this pedal. It's supposed to be a "better Bluesbreaker".
It has plenty of volume on tap which the Bluesbreaker didn't.
The Fat switch position can be a little too Fat, It would be better if that Cap was reduced by Half I believe!
Good to know, I'll remember to either socket that cap or test some different values before committing to solder. Hmmm I don't see a schematic for this yet. Which cap is tied to the fat switch?
