giovanni
I was so excited on Sunday to finish my Sonomatic build. I had just switches and jacks to solder so I did. Then in the evening I decided to test the pedal. It did not go well. The effect worked for the most part but the bypass with tail was not working or working intermittently and the effect was also intermittent at times. The tail switch seemed to be faulty, I realized I had to push against its side to make it work. I started poking around the guts to see if I had shorts. At some point I accidentally touched both + and - pins on the power plug with my handy screwdriver and I saw a little spark. After that, quiet. True bypass works (so the foot switch works) but nothing else did. I was pretty bummed and I don’t know if I’m gonna be able to fix it by the time I leave to Italy (I was gonna gift it to a friend over there).
I haven’t started troubleshooting yet. I guess I’ll start by checking the power circuit and see if I fried any of the voltage regulators. Next I’ll have to desolder the faulty switch for the tail mode. Finally I had replaced the J113 with a J112 (or viceversa I can’t remember) so I wonder if that may also be messing with the tail mode.
I’m so very bummed by this. Hopefully I can get it back in shape.
