I finished building the Dead Astronaut FX Skyscape Chorus - and there is no chorus sound. Dry signal is OK, no wet signal. The volume control works. I need clarification on the schematic. I attached the full one and a snippet where the problem lives. Before I post pedal photos and the like please take a look at the snippet. The signal never enters the MN3007. It stops at the diode using an audio probe. I assume the signal should enter the IC on pin 3 right after the diode. Correct? I re-checked the diode orientation on the board and the soldering around it and it's fine. Changing the Mix setting does nothing. The diode has been replaced with no change.
Thanks all!
Thanks all!
