Dual pedal with a flip switch
EGRENIER
So I've been planning a dual pedal build (OD and Boost in a box). I want to have a flip foot switch on it to reverse boost and OD FX order.
I have found the wiki wiring diagram, however, I do not have the 3PDT Order Switch PCB.
If I look at this diagram:
To what pin should the wires go ? I could order a order switch PCB, but with shipping and delay, putting an order just for that is not interesting.
One more question, could there be a way to connect a dual color common cathode LED to it so that we can tell which FX is running first ?
Thanks.
Thanks.
There are flipper switch diagrams on the interwebz on how to wire a said switch. I always have to google it my self. I think for the led question, you’d have to use a 4pdt.
I did loads of search for proper diagram but only found some with PCB. However after you mentioned a 4PDT, I found this:
SA = Send A
IN = Input
SB = Send B
RA = Return A
O = Output
RB = Return B
LA = LED A
LB = LED B
However, I think I would need to reverse the +/- for it to work with a dual color common cathode LED, right ?
Tare the positive to a resistor, the resistor to the middle lug, each sides log to the LED and the LED cathode to ground.
