Dumbloid Twin build
cniers13
Hello all! I have two Special overdrives built but I am wondering how I can build them to mimic the shins dumbloid twin. I would like to have one footswitch turn the pedal on and then the other select between either ch1/ch2 as seen in the photo.
Also, would a 1590bb be sufficient to make the enclosure similar to the photo with each channel running horizontally? I have knobs that size and would like them to look similar to the photo. Thanks, guys and gals!
If you use two boards meant for 1590N1 (125B) then you'll need a 1590XX.
If you've got two boards meant for 1590B, you might be able to squeeze 1590BB. For that many knobs and switches, I'd just go 1590XX, even though I try to make everything as compact as possible.
Are you running the pots the same direction as the shin with wires off the PCB Board?
