Dunwich DA-120 on a breadboard
Two boards with the same problem: very likely a common cause. # 1 cause of circuit malfunction is workmanship (it was built wrong). Look for incorrect component values. Then measure and report Vss (-9V), pins 1 & 7 on the IC, the source and drain voltages on all of the MOSFETs.
