Feral Feline
Thanks for sharing this Dan.
Would love to know if this is a worthwhile build for Bass...
Looks good. How noisy is it? That's a whole lotta MOSFETs and they are noisier than JFETs.
hello, could you share the layout schematic?I decided against the available strip board layout because I don’t enjoy off board wiring and wanted board mounted pots.
So I worked out a perfboard layout in DIYLC. Once it’s done and confirmed, I’ll post the layout. It’ll fit in a 1590XX.
I triple checked the layout against the schematic. Then I moved the components one at a time from the breadboard to the perfboard, checking along the way and talking out loud to myself. “Input, 10 meg to ground and 100nF. 100nF to Q1-2 and..and…, etc”
All of the components are placed. Tomorrow I’ll cover it in blue tacky, flip it over and start soldering.
The build is a nightmare. The traces are too tight, components to close together, the pots are a pain. Pretty much every step is a disaster waiting to happen.
Would it be feasible to replace the rotary switch S1 on this with the variable capacitance multiplier
Yeah, the six is a bit overkill given the footprint of the switch. Circuit sounds great, but that amount of nuance along with the bass/treble and active mid boost stage is a little redundant.I’m not sure if you really need all 6 choices. You could probably use a toggle switch for 1, 10, and 100nF. (Or whatever 3 seem the best)
Would it be feasible to replace the rotary switch S1 on this with the variable capacitance multiplier in Figure 21 on this article from Rod Elliot? https://sound-au.com/articles/gyrator-filters.htm#s12
Very interested in laying out a board for this but I always have such a hard time with laying out rotaries
Did you bias Q4?i built a pcb using effects layouts 'ef120' schematic and it didnt work, so made another one using this one and having the exact same issue, first time im stuck on something i cant figure out![]()
No clue. But if it’s not biased properly that would certainly cause problems.I wanna know why Q4 needs an adjustable bias.
The 1st opamp's gain is too high and it will saturate before Q4 does. Unless one dials the bias way down. Why not just hard-wire the bias to the correct value?
Thanks Chuck. I’ve been away from pedals for a while. I’ve got a Mofeta board that’s half populated and I just looked at the build doc for the Brownout, I think I’ve got the five 2n5457’s on hand. I’ll queue that for the breadboard and check it out.The MOFETA & Brownout do it the right way
