Okay I’m stuck now. I built this Duocast and cannot get signal out of it. The bypass works, LEDs come on, but once pedal is turned on, it cuts the full signal. I’ve built several PCBs from PedalPCB and first one I’m stuck on. Things I’ve tried already, checked the pin outs on the OC71, flipped the IC just in case, reflowed all of the solder joints, traced the signal as much as I could without a audio tracer. Parts came from Tayda, transformer from Digikey, and OC71 from Tube Depot. I’m honestly just stuck at this point and any help is much appreciated.
