SOLVED Duophase switched Jack
Phil hodson
Evening all,
Just about to box up my Duophase and was wondering if I have wired up this switched Jack correctly?
Sorry for the rubbish pics. It’s hard to get a decent shot.
Both sides work independently but I’m wondering if I’m actually getting one big 12-stage phaser when the Jack is not connected into the second side?
When I’m using it like this I’m just connecting the in and out to side 1? Or the in to side 1 and the out to side 2?
Thanks in advance.
Thanks! I will give that a shot and see how I get on. Still getting my head around switched jacks. Seems to be hitting a brick wall when I try and learn about them 🤦‍♂️
You should do @MichaelW. Judging by the quality of your builds you will have no issues at all. I was a bit daunted by this one. Especially the size! But it’s more repetition than anything else!
Just take your time and double check each value. And make sure you have enough 4K7 resistors and TL072’s!!
@Cybercow helped with the switching Jack (thanks @Cybercow, it works perfectly now) Everything else is way within your abilities. If I can do it!…..
Build report up soon.
