CA138
- Build Rating
- 4.00 star(s)
This was a fun build. The switches are a bit fiddly - might try traditional toggles next time.
Sounds great as a DI and is amazingly diverse. Bit of noise on the high gain settings but that is to be expected. If you want to use larger box film caps, you can fit some on the underside to alleviate the close stacking on the layout - just check the heights.
If I had to live with only three drive/distortion pedals, this would be one of them as it does well to emulate several classic amp types with plenty of room to dial it in.
