Here is Mr PCB's schematic:
Is this an example of a designer using a JFET backwards on purpose? Why would they do that? I know JFETS can be used like this but does it serve any function? What would happen if I was to turn it 180 degrees to put the drain where gate is and vice versa? Anything?
FWIW I built it exactly as per schematic and it sounds pretty good. I used a 2N5457 because I don't have any PF5102s and I have 1.17 VDC on the Drain and 1.6VDC on the Source. Sounds low to me (but what do I know??). Would it benefit from a higher Source voltage?
