Elijah-Baley
Hello,
I built it using this stripboard layout.
tagboardeffects.blogspot.com
The circuit is pretty much the same as this schematic, except for the RPD resistor. I also added the switch, and the transistors are the same.
I tried a couple of extra mods and then incorporated them into the pedal using two switches.
One in particulare has a little problem. The mod uses a fixed 3.3nF capacitor for C8 to get a low-cut mode. The switch adds an 18 nF capacitor in parallel, bringing the total capacitance to about 22nF, which is the original value.
But when the switch add the 18nF capacitor I get a pop. It's not too annoying, and I've experienced similar issues with other mods of this kind in my pedal, but I'd like to find a way to fix it.
Adding a 1M resistor between C8 and R8 across the ground didn't solve the problem.
Thanks for your help!
Fender Eric Clapton 25db Mid Boost
Collection of vero (stripboard) & tagboard layouts for 100s of popular guitar effects, with over 1000 verified designs. DIY your own boutique effects!
