Foot switch won't engage (Blue Breaker)
busterjbrown
Hey there...I'm fairly new to this stuff (this is my first build that isn't from a kit...although all my kit builds have worked great), so apologies if this is a stupid question.
So I'm having a couple of issues here, the biggest one being that the foot switch won't latch and stay engaged. If I hold it down, the LED comes on and I get a very noisy signal (albeit not exactly the signal I'm supposed to be getting from the pedal), but when I let off the switch the pedal turns off. I'm getting a clean bypass.
Could it be an issue of bad wiring somehow? Is it just a faulty foot switch? Since I'm such a novice, I assume it's something I've done wrong. Any immediate thoughts? Thanks!
Reactions: fig
It sounds like you've got a momentary switch rather than a latching switch. Happens to the best of us.
I can't account for the noisy signal, but getting a latching footswitch in there should at least keep the effect on and make it easier to troubleshoot.
Reactions: fig
Oh man...as predicted, I'm an idiot. Would have sworn I'd gotten latching switches, but just checked my order and realized I got momentary. Not sure why I didn't think to check that. 🤦‍♂️ Thanks for the responses
Lotsa people have done this (myself included), don't get down on yourself!
You might want to re-flow some of those solder joints while you've got the iron out as well. It's hard to tell looking straight down, but some of them look a little bulb-ish, which could mean that the solder didn't wet in to the pad that well.
Thanks! Not sure...I'm going to swap out the switch tonight and reflow some of the solder per @pecarry's suggestion, hopefully that'll give me a sense of what kind of signal I'm actually working with.
Sounds good. You’ll like this pedal. I just built a protein pedal and the blue side (blues breaker based) is phenomenal.
Keep the momentary and wire up the pedal with it alongside the latching. That way you can do Fig's stutter-on with the latching in bypass, or stutter off with the latching (pedal) engaged.
That's still just between effected/non-effected — to truly smash it, you've gotta have the momentary wired to ground to kill the signal completely for some Tom Morello-like or Buckethead-esque "tremolohno".
Reactions: fig
