Preverb
Do you sell the smasher switch separately? It seems like it would be better for at home playing where you might be using the switches without shoes on.Thanks. I designed them myself using the simple 555 timer based relay system. The arcade buttons are fun because of the look and sound. It sounds like an arcade when you’re hitting em. Then I wanted them to light up so I made a couple utility boards using as much surface mount components I can the pcb small to fit into single builds or custom multi builds. I can add them to any custom build for people and I prefer the relay bypass anyways.
