nikyramone
Hello everyone!
It has been a while since I last posted but I got back to putting pedals together. So far a couple came out nicely but I am having issues with the fornicus overdrive.
These are the things that work as expected:
- Signal comes in and out when not engaged
- The internal led is always on
- The external led,linked to the temporary foot switch side, gets brighter depending on the signal strength
- The right regular led turns on and off when the pedal is on and off
But here is the interesting part, I get no clean sound when the pedal is engaged. I get a very quiet, very distorted sound if I raise the volume and drive a lot, while fiddling with bias and the potentiometers. This makes me think it could be a faulty transistor since there are two through-hole j201.
I had similar issues with pedals like the chop shop or the low tide modulator and changing it the j201 to smd fixed it. However, this is coming from a kit from musikding, and I haven't seen any reviews commenting on faulty j201s on that site.
Could there be something else I am missing? Is there a way for me to identify a faulty transistor? I have searched around but couldn't find a solution.
Here is a video documenting the behavior ->
and I attach some pictures of my shameful soldering.
Thanks!
Thanks!
