I did some sims just to compare side to side, here's some observations.
We have those three circuits, left to right:
- First one is a fairly standard jfet gain stage, with "cathode follower".
- Second one is the same, but with a follower nicked from AMT L2 pedals (those that have it, e.g. S2, D2, M2...)
- Third one has a bootstrapped follower.
All are biased equally, and the follower has a 26k load (akin to the AMT tonestack with bass and treble at zero, mids fully open).
Taking the signal at gate, it is the same for all three circuits, since they are biased the same, no resistor on source and 11.2k on drain, featuring positive lobe clipping.
Standard circuit: gain stage inverts signal, positive lobe bangs against the positive rail on drain, and negative does not quite reach the negative rail, merely amplifying the previous gate clipping. At the output of the follower, we have clipping on the negative side due to the 26k load + a fairly high value on the follower source (47k).
AMT circuit: same as above, except that the AMT diode-to-source contraption compresses and prevents the positive side of the signal from reaching the rail, clipping 2v before it. Not knowledgeable enough to explain the theory behind it, but it does a fairly good emulation of what happens on the last stage of, say, a JCM800.
Bootstrapped circuit: we have more gain due to the bootstrapping (see the Merlin Blencowe chapter on it), and negative side clipping much earlier than the others, that "pushes" the negative signal (effectively soft clipping). The follower output looks quite smoothly compressed, and overall different than what you would see on the above circuits or a standard valve stage + cathode follower.
If we reduce the source resistor, or increase the load, the negative clipping on the follower will decrease (cleaner signal). If we replace the load with a tonestack, the knob positions will affect the amount of clipping.
As for circuits, this one here is not where I would like it yet, but getting there. Kinda hot rodded marshall tones. LND150 works well as an input stage, since it won't ever feature blocking distortion even when slamming it at capacity, and works nice as a last stage too, clipping a bit softer than jfets and without gate cutoff distortion. Can be biased to clip quite symmetrically, and does a reasonable "power stage" clipping thing.
Hope this helps
