Aria James
I recently assembled a fuzz pedal on a custom PCB but I'm getting no audio output—only a faint hiss when the volume is high. During troubleshooting, I remembered this Proteus simulation guide for ultrasonic sensors, showing how audio signal paths and proper signal conditioning should work:
www.theengineeringprojects.com
I also reviewed their detailed walkthrough on analog amplifier basics, which is very helpful for understanding gain stages, and I checked Electrosmash’s fuzz face analysis along with this Hackaday post on debugging DIY pedals. Has anyone faced a similar issue where the pedal seems wired correctly but output is essentially muted? Could there be subtle faults in grounding, coupling caps, or biasing that's preventing signal flow?
Introduction to HC-SR04 (Ultrasonic Sensor) - The Engineering Projects
A brief read on the Introduction to Ultrasonic Sensor HC-SR04. It is a sensor based on transmitter and receiver where former is used to send the waves...
