Possibly a silly question but I've just completed an FV-1 (SMD PedalPCB Arachnid with some slight mods) build - well, the PCB anyway xD One thing that would be nice to have is "tails" / "trails" so that when the pedal is disengaged, the echos (or whatever) continue.
As it stands right now, the pedal is "true bypass" and you can't do this in true bypass mode which seems obvious to me looking at the schematic. To get the "tails", my understanding would be that you'd need the switch that disengages the pedal to disconnect the input signal from the effect / FV-1 chip and re-route it to the output jack as with true bypass but you'd *also* need to keep the output from the effect / FV-1 chip and keep sending that to the jack output also.
So clearly you'd require some kind of mixer to do this. My feverish brain came up with the following:
So the SW3A would be one of the switches in my relay bypass in practice but as above, it's simply a single SPDT switch. In "on" position as shown above the signal from the jack would go to the input of the effect. Output of the effect would go through the mixer to the output jack.
With the switch "off" (ie. pedal disengaged), you'd essentially be just mixing the jack in and effect out signals.
Would this work or am I heading down the wrong lines here?
