Hi!
Thanks for sharing the Sandbox FV-1 design. I’m planning on using it as the basis for an internal FX section in a synth.
I’m trying to understand the input side a bit better. If I change the circuit to run from +15 V instead of +9 V (and shift the mid-point bias from 4.5 V to 7.5 V), is that enough to allow higher signal levels at the input? When testing, I noticed that also reducing the two equal-value resistors around the op-amp (to 10k) reduced clipping with hotter signals, and those changes combined seemed to give the same output as your design, but im not sure if this maybe is altering the noise filtering?
Also, what kind of signal level was the input of the pedal designed for originally (roughly)?
And, what about crystal speed? The manual states that a 48KHz crystal may be used to gain additional bandwidth, but is this straightforward or does this have other implications to circuit/noise/patch running speed etc?
Thanks again for making the design available.
