Erik S
I was hoping to finish this up this weekend for my brother in law, but I hit a road block when I went to drop the board in the box.
As near as I can tell the indicated hole location for the toggles is off on the drill template by half a hole diameter. Per the listed dimensions and my print, the toggles should sit .400” higher than the lower pots.
Measuring from the PCB, that distance looks to be about .275.
I can probably slot the toggle holes down .125 and put the big ugly tab-washers on there and just about cover the mess, but I’m not thrilled about it. I’d just drill another enclosure, but this glow in the dark one was a customer request and I’ve just got the one.
If I take the toggles out all the pots line up good, so the rest of the template seems right.
