Ginsly
Although I haven't used them in a build yet I have an assortment of ceramic discs from a few different sources, and I was shocked to see how low they were when tested. For instance, several 100nf caps tested at around half of the stated value, and it didn't end there. Used a couple different testers.
It kinda made me re-evaluate my capacitors and why I use certain types in certain situations. For the most part, I've stuck to this:
pF values - C0G/NP0 MLCC (TDK blue guys)
nF values (inc 1uf at times) - polyester box film (mostly Kemet white 100v - R28 series)
uF values - electrolytic (mostly Nichicon/Rubycon various voltage)
All of the above seem to have good tolerances.
*I also have non-C0G/NP0 yellow MLCCs that I use for primarily for breadboarding
*Additionally, I have mylar greenies and some reds (metallized polyester or polypropylene?) that I've used in builds, but can get large.
Some thoughts that popped up:
- Although many use them without issue, I clearly have some really bad ceramic discs - maybe they're generally known for bad tolerances, though..? I'm tossing them, but is there any reason to replace them with better discs rather than simply focusing on MLCC, box, and mylar for non-polarized?
- To that end I rarely use the yellow MLCCs (likely X7R?) caps in builds even though they're nice and small - if box film fits, it seems to be the better choice with better tolerance. Is that a good baseline approach when in the audio path? It sounds like I could easily use X7R MLCCs without issue for any capacitor that goes to ground or is used for DC filtering - seems like this may be a system some builders use. That being said, I'm largely building dirt pedals (for now), and I could likely use any type of MLCCs without issue (as long as they're within an acceptable tolerance).
- I have some tantalum caps, but honestly don't know where or why I would use them. I've seen some people here use them in place of ALL electros, and some people never use them. There are some builds that use both - I have a Klon board that features a bunch of electros and one single tantalum - wondering why that might be.
- I doubt silver mica is necessary for any of the builds I'm doing, nor can I drop that kinda dough on caps!
This is all a longwinded way of saying that what I'm doing at the moment works, but I'm still a little unclear about a few things. I've pored over several posts, but would love some additional opinions!
