Troubleshooting a little buzz when I'm playing - this is on the Complex OD and Lead Solder OD, but the question is in general - noticed something with the grounding, and I'm wondering if there is some redundancy going on. If so, it could be a culprit for extra noise due to a ground loop?
I know these are high(ish) gain circuits, so some noise is to be expected. I've also read that if there is noise when you let go of the strings (and it goes away when you touch the strings or any other metal part) that it could be a grounding issue with the circuit.
(Could be the pickups - they're Mojotone '59 Clones that haven't been wax-potted.)
I typically only connect one of the jacks' ground lug (input or output) to the board's ground pads, as the other jack will connect via the inside of the metal enclosure.
My question is this: do I need to connect both to ground, or would that cause a loop?
Just running through the options.
