SillyOctpuss
I didn't put this in the troubleshooting section because the pedal works just fine but has a very harsh quality to the overdrive especially on chords or notes as they die away.
I've attached a gut shot and my voltages below. I'm a bit perplexed as to what could be causing it. If you were going to start changing parts what you change out and why? I've played a real peacekeeper and it was definitely smoother/less harsh than this
There have been no parts subs from the build doc and the 2n2 cap over the resistor was to test if I had an earlier board which had an issue though this ultimately wasn't the case
