LittleRummyTumTum
I'm having a bit of an unusual issue with a Guitar/Bass Driver V2 build from GuitarPCB. Schem/Layout is here: https://guitarpcb.com/wp-content/uploads/2018/06/BD_GuitarBassDriver-Board.pdf
Basically the effect works, but is very low volume with every knob dimed. I've worked my way through the board with an Audio Probe, and this is where it gets confusing: I get ample volume/signal coming off Q9, but probing the input of c16 the volume has dropped.
Any thoughts here? Looking at the PCB the traces don't appear damaged nor can I see any shorts between Q9 and c16. I did considering swapping out both components, but the signal loss is clearly happening somewhere in between. I'm tempted to just connect Q9s drain, C16, and R27 off the board to bypass it see if that corrects it.
Also note that Q9 was subbed with a J112 - though as the signal coming off the drain with the probe is fine I don't think this is the issue.
EDIT: Scratch that I'm an idiot - I'm actually getting signal coming out of the GATE of each transistor, not the drain for some reason. So if I probe Q1 I get signal on the Gate and Source (probing the leg itself) but nothing on the drain, same applies to Q9
