eh là bas ma
I built the GuitarPCB Bass Overdrive a couple of years ago, never really could enjoy it because of some kind of bass cut. Compared to other Bass dirt circuits, it felt like it was missing some depth or something.
I always liked something about it though, it sounds quite convincing as a Bass tube amp emulation.
Two days ago, I thought about adding a clean blend control, in order to restaure a bit of bass frequencies in the distorted signal. I wasn't sure how to do this, so I posted about it on diystompboxes.
The final result is far beyond my original expectations.
Thanks to the amazing help of dear forumites, I ended up building an extra buffer on perfboard to fix a "quick hack" for the blend control, and using a 3PDT toggleswitch to change caps values at three locations on the circuit : an effective bass boost and an extra blend control !
This was built without mods in 2020 (you can guess from the abundant wiring that it was among my first builds), it's the v.1 :
I am sure these mods can be done on the v.2 currently sold at GuitarPCB's.
All the details about how to build the mods are in this thread :
If you built one of these Bass OD boards, I strongly suggest to consider these mods, I couldn't be happier with how it turned out.
How to connect a Blend circuit to an overdrive ? [SOLVED]
www.diystompboxes.com
