Happy Holiday PIF from GenX Santa
bean
Legume Liaison
I'm doing one of these on the mbp forum so I will do one here as well.
I have a PIF that will allow you to build a pedal that does not exist in any form! What is it??
I did this a proof of concept while I was doing some work with Function F(x) on their 2in1 concept (of which a couple pedals have been released so far). This is not part of their lineup, I just did it for me. It is a double Timmy pedal. So, two independent Timmy circuits in one enclosure. But, here's what makes it special:
Order switching
Soft touch bypass
3(!!!) different bypass modes, A and/or B, A and B , A swap B.
There are a couple caveats: there is no project documentation so you will have to build off the schematic (of course, I'll answer questions if you have them). The only docs you will get are a schematic and drill file. I will give you my art file too if you want to use the same artwork. I will also include the pre-programmed microcontroller you need for the two relays used for bypass.
THIS PIF IS AVAILABLE TO ALL MEMBERS WORLWIDE, NO SHIPPING CHARGE. BUT....it will be a deep dive for long time DIY'ers. Here's how to win it:
This PIF will go to the first member that replies to the following:
What URL re-directs to pedalpcb.com because of a stupid joke a made for single day way back in 2018?
NOTE: This is for the PCB, not the pedal in the pic. That one is mine
