kylewetton
Here's the schematic attached as a PDF, as you can see, the EQ (EarthQuaker Tone Job), has a buffer before and after the tone network, I'm wondering
1. Should this buffer be moved before the clipping stage of the BMP? If so, where should it go in relation to the input resistor and capacitor?
2. The coupling caps between the input buffer of the EQ, If I moved the buffer, what makes sense to take with it and what should be left behind? (I'm trying to avoid copy-past'ism and learn more)
I've breadboarded this and it sounds great, I just wonder if I'm doing anything redundant or odd here
