kylewetton
Here's what I have so far, as you can tell I'm still very much learningkylewetton: how about you draw up exactly what you built so we're all on the same page.
It's all plugged in pretty tightly, here's what I'm gettingThat's all good except I would ditch C10. It's not needed and could cause IC2.2 to oscillate. I don't think it's causing the bias problem. You have measured all 8 pins on IC2?
They should be:
1: 4.5V
2: 4.5V
3: 4.5V
4: 0V
5: 4.5V
6: 4.5V
7: 4.5V
8: 9V
You're sure the IC is plugged in correctly? No bent pins and proper orientation? We've all screwed this up at one time or another.
Pins 6 & 7 are supposed to be connected together, so why are their voltages different? Look for missing connections. I think the IC is fine and you made a mistake. Let's see a photo of your breadboard.It's all plugged in pretty tightly, here's what I'm getting
1 8.7v
2 8.6V
3 8.5V
4 0V
5 4.6v
6 4.6V
7 8.6V
8 9.2V
But be worth trying a different IC
Hmmm nah at the moment it’s just Q1 - Q3 of the big muff straight into C12, so I just have the one IC, level is now the volume out right at the output. How dumb am I being? Should I bring back a buffer?Hmmm. I wonder how that IC got damaged...
The important thing is it's working now.
You're putting the variable gain stage (U2B and associated parts from your BvF sch) to the left of C12 and after the BMP, right?
