It worked. I was able to convert it. Thank you soo much. So, I have 1 more thing to ask I hope it's ok, generally speaking when you design a patch, before you save it to hex file is something that needs to be done first? I may be asking for alot and I hope you might have some knowledge of what I'm speaking of. So here's my dilemma...
So designed 8 patches on Spincad designer then I exported the 8 patch bank as a hex file and saved it on my documents directory on my computer. Then I did the conversion of hex to bin, thanks to your help, and was able to flash the 24lc32a eeprom successfully. Now when install the eeprom on the fv1 multi effect pedal, I get none of the 8 algorithms working. Am I missing a step? I hope you can shed some light on what I'm doing wrong or missing and if not that's ok you have been so helpful already and I appreciate it
