That’s very clean! I forgot the Wizard has led clippingAnd you must have quite a collection of transformers by now…
Time to order thenI am actually running out. After the Deliverance and X88R builds I'll have just one 320V toroid left. I do have 2 full amp sets after the Model T though. One is Park 75 spec and the other JTM50.
Time to order thenlucky for you, I guess you use like 100VA so it’s probably not that expensive. And not output trans…
230-240V/50Hz mains here, but better to mention 60Hz to make it more easy for you weirdos with all kind of wacky wall voltages. Nope, it doesn’t go away without guitar/jack grounded. Added V2a cathode bypass cap to be sure few months old tube isn’t doing heater leakage via cathode, but no use. Made clean sound worse to be honest! Gonna remove that tomorrow and try setting bias colder to make sure it isn’t the cure here. Also tried to induce earlier cutoff experience with 2in1 fuzz pedal, but I’m happy it didn’t happen and buzz wasn’t really audible when raising volume enough to mask it into distortion. So I’m almost there with troubleshooting!If it's working well I wouldn't worry about ripple on the bias.
Are you sure it's 60 Hz... not 120Hz? I guess I don't know much about Finnish power haha.
Does it go away without the guitar plugged in and the input grounded?
Following a short exchange with @vigilante398 I did a couple of simulations on JLC for a custom chassis. C-shape, 2mm aluminium. 9cm high, 25cm deep, 45cm long, with 3cm folds to be able to screw the chassis to the headshell:
Base: 10€
Powdercoated: 13€ (!)
With enough holes for tube sockets, IEC, fuse, jacks, pots etc... wait for it... drum roll...
11.50€. Yes, the holes cost only 1.50€. They are laser cutting too so expect stuff to be exactly where it should be. That means 14.50€ if I powder coat that. I find it completely nuts.
Shipped to Germany, all included, I would be looking at 55€. For reference, a similar quality non-drilled chassis and powder coated only on a single face would cost me 50€ shipped from a european retailer (and it would be a pain to find anything else than 1.5mm which is too soft imo). I might also look into silkscreening it and not bothering with vynil but that would require more work on my end.
I am very much considering it. Very, very minor incovinience of having to model this compared to drilling massive holes in a powder coated enclosure, risking to melt the powder coat, plus the "joy" of filing squares for switches etc, for 5€? Yes sir.
I never priced a chassis job but that seems cheap to me.Following a short exchange with @vigilante398 I did a couple of simulations on JLC for a custom chassis. C-shape, 2mm aluminium. 9cm high, 25cm deep, 45cm long, with 3cm folds to be able to screw the chassis to the headshell:
Base: 10€
The drilled and coated chassis shipped to me ends up being the same price as a raw piece of aluminum folded four time shipped to me from the same country. And that is using my trick of not ordering a chassis, but ordering a custom piece of gutter from an aluminum provider.I never priced a chassis job but that seems cheap to me.
As most actual custom amp chassis makers still fold a sheet and drill/cut by hand (and have to make a living), the pieces usually end up being at least twice as expensive (without powder coating) before shipping. A classical Hammond is like 40€, but it flimsy as hell imo and not custom sized (and obviously raw and not drilled). So yeah. I will invest some time and see how far I can push it with a silkscreen etc but JLC is becoming crazy competitive for this. Imaging if I had ordered my PCBs in the same package - I would have saved an extra 30€ of shipping or so!
Still missing my transformers so turned to 3D modelling.
As a bonus, I am spending some time reading up on amp design and started brainstorming on the possible "child" between a Deliverance and a VH4![]()
